Fighting with doors!
I have a 07 Sahara 2 door with the 3 piece freedom top. The problem that I have is when I take the front of the top off and put it back on the doors are a pain to close. I understand its an american vechicle and it is built to be beat, but I would rather not slam the doors all the time.
I have checked to make sure the top is placed on correctly in line with the windshield and the pins drop in the holes, passenger side on first. And I still have difficulty with the doors.
Any suggestions?
Any suggestions?
Jword, the culprit is definetly lack of ventilation in the JK..
If you try and open a window (about 1/4 or more) and close the door it closes easily... I have dual tops and when I have my soft top I need to get used to closing them lightly then when Im using the hardtop its back to slamming those doors. I was thinking of adding those vent visors so that I can keep the windows open a little bit for day to day driving... to me it doesnt seem that slamming the doors can be a good thing
Yeah trick is to leave a window partially open. All hard top Jeeps ever made have been like this. The soft top is also. but to a much lesser degree because the air volume leaks out the zippers when you close the door.
Another thread on the topic:
https://www.jk-forum.com/forums/show...ght=sheet+door
keeping another window or door open helps a ton, but so does having the right adjustment on those damn latches.
As others have said about the Jeep doors being tight to close: Nature of the beast. If you ever drive through 30" or so of water, you'll appreciate that the Jeep interior compartment is sealed so tight.
