Fan motor question.
Fan motor question.
I looked but couldn't find. The radiator fan on my 07 no is squealing horribly. Can you replace just the motor or do you have to get the hole new fan assembly? I've been looking,and can't find the parts online anywhere
I had heard of guys buying just the mother before I can't seem to find it either. I found the whole fan assembly for around $128 @ moparpartz.com. Good luck with your search. I would try a junk yard first if you do not want to spend that much...
I just bough a new fan for my 07. I got it off eBay. I've had it on there for 2 weeks. So far it works great.
http://m.ebay.com/itm?itemId=290909041721
the squealing is either the belt of the bearing on the fan (loose belts squeal so do bad bearings), either one is way cheaper then 100+ for a new fan.
