Factory Alarm - How does it work and how did thieves get around it?
Old 02-07-2011 | 01:08 PM
dstock's Avatar
Default Factory Alarm - How does it work and how did thieves get around it?
My JK was broken into this weekend. Factory alarm did not sound and there is no evidence of how the thieves were able to defeat it. Passenger front door was found partially closed.
How is this possible?
Oh and did I mention? The ass-clowns also stole my gf's Cherokee!!!!! Granted it did not have an alarm.
Anyone have any ideas? I know I am not the first to have this issue.
Thanks.
-Dave
Old 02-07-2011 | 01:18 PM
Godfather901's Avatar
I just read somewhere that the tire sensors can be hacked with a laptop and the alarm disabled, also the brakes, and the ecu. Easiest way I could think of would be to pop your hood and disconnect the battery. No batt = no alarm.
Old 02-07-2011 | 01:34 PM
dstock's Avatar
Everything was intact under the hood, nice layer of dirt in the engine compartment was undisturbed, otherwise I agree, this would be the easiest way.
Old 02-07-2011 | 01:36 PM
westchester's Avatar
I No batt = no alarm.
Yup, no security on the JK's hood makes opening it too easy, then jimmy the doors or crawl through the soft top rear.
I hope you catch the bugger trying it again
Old 02-07-2011 | 01:44 PM
dstock's Avatar
Agreed, but since they didn't touch the battery and I have a hardtop...wtf? Maybe a rolling RF transmitter to defeat the alarm I guess?
Old 02-07-2011 | 05:02 PM
otnman's Avatar
maybe this?
ht tp://carscoop.blogspot.com/2011/01/swiss-researchers-show-how-easy-it-is.html
Old 02-08-2011 | 05:54 AM
senfinger's Avatar
I had a civic that was broken into in 2000 and they were able to run a coat hanger/crack of window at the top in and hit the electronic lock. If you unlock from the inside after locking the vehicle with the FOB, the system thinks something opened from the inside/no big deal and it doesn't go off. That's how mine was done-
Old 02-08-2011 | 06:19 AM
sixty5vdub's Avatar
Thanks.
-Dave
Sorry to hear about your misfortune. Thieves can be quite creative in their attempts to steal your things.
Maybe they were able to use something as simple as a coat hanger to hit the power lock switch to unlock the doors. Not sure if this would trigger the alarm or not.
If they didn't disturb the battery, did they cut the wire(s) to your horn? This would keep you from hearing the alarm when it was tripped.
Most thieves aren't going to invest money into scanners and code grabbers. Coat hangers, slim-jims, box cutters and rocks are far cheaper and just as effective.
I hope they find the scum that broke into / stole your things.
Anthony
Old 02-08-2011 | 06:25 AM
senfinger's Avatar
Edited... = _)
Old 02-08-2011 | 06:31 AM
bstpierre's Avatar
Originally Posted by senfinger
See my prior post... it DOES NOT trigger the alarm-
It does trigger the alarm on some vehicles (probably most newer vehicles). I know it does on the Ford Freestyle and Taurus X. I think it suppose to on the Wrangler, too.
Quick Reply: Factory Alarm - How does it work and how did thieves get around it?
