ESP BAS and Traction Control Light?? Help Trouble Shooting
Old 12-11-2013 | 09:18 AM
  #31
aaronstephen's Avatar
Originally Posted by corupt1
Had a similar issue with my 09 Ram and it ended up being a bad wheel speed sensor. But with the steering wheel being off, I agree that probably is the issue.
Before you throw more parts or work at something that could have multiple causes, it might be worth while to have the error lights diagnosed. Not sure if an auto parts store OBOII scanner will work or to take it into a dealership. If it was a wheel speed sensor, the dealership should be able to tell you which one so you are not trying to figure out which one (or more) of the 4 sensors are bad.
So far so good with the lights staying off. Adjusting the drag link must've helped. We'll see though, because the steering wheel is still a touch off. The drag link is completely seized. Eventually that is gonna need replacing. If the light comes back on I'm likely to take it to the dealership and try and nail down the problem. Thanks
Old 01-29-2014 | 11:09 PM
  #32
Arctic Blue's Avatar
2012 sahara
35,600 miles (warranty over soon).
Speedo went to zero, traction light, abs light, and ebrake light all came on and heard a chime about 2 times. This occured ten times. Took it in, the replaced the wireless control module. Afterwards the low tire pressure liggt was constantly on. They had to reprogram the tire pressure sensors to the control module. All was fine.
Since then I wired in an ESP kill switch.
Two or three weeks later the same thing happened once. I flipped the ESP kill switch, pulled over, shut off and restarted the jeep. That was a two weeks ago and been fine since.
Sound like a clock spring or no?
I have an appointed to take it into the dealer in 6 hours.
Take it to dealer....Yay or nay????
Sent from my SCH-R970 using Tapatalk
Old 01-30-2014 | 06:02 AM
  #33
Jersey_Devil's Avatar
Originally Posted by Arctic Blue
2012 sahara
ABS Module.... It blew out on mine. Let the dealer do it under warrenty. It's cheaper
Sent from my obama monitoring device
Old 01-30-2014 | 06:30 AM
  #34
Today was the appointment for the jeep. Dropped it off. Got a loaner. Got to mcfarland. Flat tire. Called and was told I had to change it. I wanted home so I tried. Took off my jacket and work shirt for obvious reasons. Cold dirty and greasy I find a locking lug nut and no key for it. Call back and theyre sending a tow. Also said there are no stored codes so they cant do anything to the jeep
Old 01-30-2014 | 06:31 AM
  #35
2 hours for a tow so I said im leaving it here. Im not putting anything back together of shut or locked.
Old 01-30-2014 | 06:48 AM
  #36
OMG they really boned u! I'm sorry to hear this. I hope ur day turns around soon...
Old 01-30-2014 | 06:51 AM
  #37
Yup. Left it at a gas station. Jack up. Spare on the ground. Tool on the ground and lug nuts off.
Old 01-30-2014 | 07:35 AM
  #38
Not only that. Got the jeep back...half way home..... THE DASH LIT UP AND CHIMED AT ME! back at the dealer waiting
Old 01-30-2014 | 07:47 AM
  #39
That's how mine was, the lights would turn on and off, and to top it off, I was happier with them ON cuz when they were on it shuts off the safety features, when the lights were off the safety features were on the fritz so the abs would kick in in dry weather barely applying pressure to the brakes. Let me tell u, abs is great when it's slick out but in dry conditions as is scary cuz u can't stop properly. I REFUSED to let them tell me "they can't figure it out" that's bs ur the dealer, fix that shit! Sure enough they came back telling me abs module was bad. Don't take no for an answer from them, that is unacceptable.
Old 01-30-2014 | 07:49 AM
  #40
He's the link to my thread when it happened to me
https://www.jk-forum.com/forums/modified-jk-tech-2/esp-bas-traction-control-lights-help-282346/
Edit: just realized this one was because of New track bar.... Still looking for the other thread, u can see in this one I said I had sensors replaced at dealer few weeks prior,but unfortunately I don't mention the abs module... Hers my W/O from the dealer
Quick Reply: ESP BAS and Traction Control Light?? Help Trouble Shooting
