ESP BAS and Traction Control Light?? Help Trouble Shooting
Old 12-10-2013 | 05:59 AM
conifers4's Avatar
My abs module blew out and did this too. Might not just be a sensor..... That's what everyone told me too but it was definitely a lot more expensive than a sensor.....
Sent from my obama monitoring device
Like how expensive Jersey?? Did you replace yourself?
Old 12-10-2013 | 10:56 AM
aaronstephen's Avatar
So trying to adjust my drag link to straighten my steering wheel but it doesn't seem to want to move. I've sprayed it with pb blaster and it's still seized. any suggestions?
Old 12-10-2013 | 11:18 AM
tribulation138's Avatar
Map gas.....
Old 12-10-2013 | 12:28 PM
Originally Posted by tribulation138
Map gas.....
Old 12-10-2013 | 12:30 PM
Jersey_Devil's Avatar
No dealer did it and warrenty covered it I only had a 150 deductible. Easily changeable it's right on top and the part is pricy if not warrantied I dunno how much exactly tho
Old 12-10-2013 | 12:57 PM
Map gas tourch! Or propane you know?
Old 12-10-2013 | 01:17 PM
Gotcha
Old 12-10-2013 | 03:43 PM
No luck with the torch... 😁
Now I'm at a loss.... ????
Old 12-10-2013 | 04:42 PM
jeeperjkjeeper's Avatar
did you try a pipe wrench on it? seems odd...once I loosen the 2 15mm bolts I can rotate mine easily by hand? give it a couple good whacks with a bfh and soak with pb blaster overnight.
Old 12-10-2013 | 07:16 PM
ezdoesit06's Avatar
Could also need to get the abs module initialized.
Quick Reply: ESP BAS and Traction Control Light?? Help Trouble Shooting
