esp/bas, traction control light
I've read through many threads but can't seem to find the answer. The two lights come on and stay on for about 30 mins. Then they seem to go off most of the time when it warms up. So I think it's good, then the next day they're back on. I've adjusted the steering wheel many times and it's as center as it can be.
Check your wires going to your wheel sensors. Also try disconnecting the negative terminal in your battery for about 10 minutes. That should clear any soft codes you may have.
Have you been wheeling lately? Did you drive through any standing water? You may have water intrusion in the sensors. If so you can try replacing the O-Ring packing around the wheel sensors in the axle.
There's no abs light on so I don't think it's the speed sensor, had that problem before. I was just pulling out of a store in town when the two lights came on and haven't been doing any wheeling recently.
