Esp
#23
It has to be running to turn the steering wheel.
#24
This is the process I used with my 12 Rubi and it won't work:
The following procedure will disable (or re-enable) ESP functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF. After performing the ESP disable procedure correctly,
“ESP OFF” will be displayed in the odometer for approximately 12 seconds each time the ignition is moved to ON.
Repeating the ESP disable procedure will re-enable normal ESP operation.
#26
I'm getting the same darn thing.....Rats.....My Rubi is a 2010--which fuse do I pull to disable the system? I'll be careful about no ABS, but then I haven't had ABS brakes for 20 odd years of driving, so I'm thinking it won't matter too much!!
#27
