Esp
Old 04-26-2012 | 07:40 AM
  #21
AJMBLAZER's Avatar
Originally Posted by kh202
Disagree ...
Get this every time I click on the link:
vBulletin Message
No Thread specified. If you followed a valid link, please notify the administrator
Old 04-26-2012 | 07:50 AM
  #22
kh202's Avatar
Ah I'm on iPhone...dunno. Link works but the steering wheel dance doesnt for me lol
Old 04-26-2012 | 09:21 AM
  #23
jkrubcon's Avatar
Originally Posted by Puregolf
Did you try it mine is a 2011. I can't imagine why it wouldn't work in a 2012. I followed the instructions except my jeep was running the whole time. I read where you are only supposed to have the jeep on and not running.
It has to be running to turn the steering wheel.
Old 04-26-2012 | 09:22 AM
  #24
jkrubcon's Avatar
This is the process I used with my 12 Rubi and it won't work:
The following procedure will disable (or re-enable) ESP functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF. After performing the ESP disable procedure correctly,
“ESP OFF” will be displayed in the odometer for approximately 12 seconds each time the ignition is moved to ON.
Repeating the ESP disable procedure will re-enable normal ESP operation.
Old 04-26-2012 | 10:53 AM
  #25
Bodar's Avatar
Only thing I dont like about this in my '11 is everytime I come to a full stop my jeep dings twice. And the lights on the dash, but I can deal with that, lol.
Old 04-26-2012 | 01:10 PM
  #26
PaddyMurphy's Avatar
vBulletin Message
I'm getting the same darn thing.....Rats.....My Rubi is a 2010--which fuse do I pull to disable the system? I'll be careful about no ABS, but then I haven't had ABS brakes for 20 odd years of driving, so I'm thinking it won't matter too much!!
Old 04-27-2012 | 01:30 AM
  #27
Puregolf's Avatar
Did you set your parking brake? That is part of the dance and if you don't set the brake it might not work.
Old 04-27-2012 | 03:02 AM
  #28
jkrubcon's Avatar
Yes..........
Old 04-27-2012 | 06:08 AM
  #29
Bushmaster's Avatar
You should disable esp and traction control for sand driving. It makes life easy.
Old 04-27-2012 | 01:36 PM
  #30
Rapidfire's Avatar
I really do hate that every time i go on and on/off ramp my jeep freaks out and starts frantically braking. =\
Quick Reply: Esp
