Engine Tick Diagnosis
I've exhausted resources trying to diagnose this engine tick. Two different dealers say it's not an issue, but I call bullshit. None of my friend's JK's have this noise, and it wasn't there 3 months ago.
HERE ARE THE FACTS:
- The tick is coming from the oil pump/ lower timing chain area
- It is ONLY audible while engine is warm and at idle
- When engine is at higher RPM than idle the tick goes away
- This engine is a new replacement and has 11,000 miles with 1,000 left on warranty
-Oil Pump was replaced 10 months ago
TROUBLESHOOTING I'VE TRIED WITH NO IMPROVEMENT:
-5W20, 5W30 Oil, both Syn and Dino, Lucas Oil Additive
-Removed Oil Pan and found nothing loose, no metal shavings
-With a Mechanic's stethoscope I can only narrow it to the lower timing chain/ oil pump area.
I called Chrysler and explained the issue already. They said a Dealer would have to find a problem before they'd help me. Well, the dealers say it's fine so here I am. Would you be satisfied?
Why does my engine purr like a kitten when cold and sound like an old diesel when warm? Why doesn't thicker oil improve it? What could make this irregular tick?
Thank you for any suggestions
http://www.youtube.com/watch?v=IzO2nP5VTTw
HERE ARE THE FACTS:
The dealer says there is no problem with that?
That sounds about the right frequency for an individual piston/rod to see a power stroke at idle.
It's also is about the right frequency for an individual lifter to see a cam lobe at idle.
I would look for a problem in those two areas first.
Have you checked the oil pressure with a gauge?
I would agree that it's probably the lifter(s) tapping. Was this a Chrysler crate engine that was installed by the dealer under warranty? And if it was, there was a problem where the oil pump had to be replaced already on a "new" engine? Or, is this a remanufactured engine? Did you purchase it with this engine or was there obviously a problem with the original engine after you bought it and the dealer was authorized by Chrysler to replace it? If it persists they should be replacing the lifters I would say. It shouldn't be making that type of noise with only 11,000 on it.
The oil pressure was checked by dealer #2 at my request and was good. Would damaged cam lobes be heard from the lower front of the engine?
This was a new engine block and heads warrantied by Chrysler for a spun bearing and heat damage. Everything else is original except the oil pump replacement 1 month before the engine. Lifter tapping is out due to the location of the noise near the oil pump.
I suggested valve train or piston/rod as the source due to the frequency of the ticking. It is approximately once every two crank revolutions, which is exactly the frequency for valve trail loading and piston/rod loading.
If the tick is actually coming from where you hear it, I suppose it could be a timing chain or cam sprocket issue.
The oil pump turns at the same rate as the crankshaft, so it would most likely make noise at twice the rate you are hearing.
These are just ideas, since you will probably not be doing the troubleshooting while it's still under warranty.
Looks like the chain stretched and possibly jumped a cog on the camshaft.
