Engine swap checklist
I am having my engine replaced in a 2013 JK 3.8L. My question is; is there anything else I should replace while doing the engine? ie. water pump, oil cooler, etc. I am having it done professionally and not doing it myself and will take their recommendations, but looking for anything to keep my Jeep running long term.
h60taxidriver (11-07-2021)
Typo and you mean 3.6L in your '13? Guessing so. If you have the original WP, I don't think it would be a bad idea for an extra $80 or so to put a new one on the new motor. On that 3.6L if you have to replace the WP, the alternator comes off and unless you have the radiator out, it's a little tight working in there getting to the WP, so decent preventative maintenance. I swapped WP on my '13 about a year ago when I was installing a new radiator. I was a little surprised the inside of my gasket looked like this -
trcmag (09-02-2021)
My engine quit, having to replace. Do you have a break down on what was done? Want to pre-buy parts. Unfortunately, unable to convert to V8, just don’t have the time. If able, please share items that added cost so I can start. Thank you
Engine Replaced? Is this a rebuild on your old unit or a drop in new one? I would definitely check the oil cooler and do what Resharp suggests for the WP. PS pump, alt and AC pump are all bolt on and I would suspect you are reusing those 3.
