Engine rpms slow to drop when shifting
Hello everyone. I recently bought a 2012 jkur. It was a big change from driving trucks for years but but so far I'm loving it! I have a question regarding engine rpms while shifting. Every time I depresse the clutch to change gears the rpms "hang" for a moment before they slowly drop. I know its all to do with the Drive by wire system I just feel like I'm going to kill my clutch in no time if I let the clutch out to soon. I've tried to research this lots already but I was not able to find any conclusive results. I've read that the transmission in the 2012's needs to be shifted slowly to compensate for the slow drop in rpms and it shifts fine if i just wait to let the clutch back out, but I was wondering if I could make adjustments to how fast the engine idles down between shifts with a tuner like the aev procal or any other tuner out there? I've only ever owned trucks with manual transmission however this is the first dbw vehicle I've owned and all the computer controlled crap is very different than I'm used to. Making slow shifts isn't really a problem it's just different from what I'm used to and if there's a way to make it the way I'm used to it would be that much better.
It def takes some of the enjoyment out of driving stick. So to date there is nothing that can be done about this correct? It's nothing I can't live with but I would love to have the revs drop much quicker.
Theres a product, which I'm drawing a blank on the name right now, but it plugs into the pedal and u can set in 3 stages the pedal sensitivity.. Someone help me out with the name....
Aside from that as others said u kinda get used to it. I had to... Its nothing like driving a reg cable operated throttle..
It is a pain..
If you try altering your driving style (clutch/throttle operation) slightly, you may find it not as bothersome.
It is possible to row through the gears pretty quick without feeling like you're using the clutch as an engine brake for each gear. At times the motor seems to do better with short/quick stabs of the throttle. Mostly it's just really well timed clutch/throttle action.
It is a pain..
When you get used to it you'll find your are letting off the gas a second before pushing the clutch in and pushing the gas pedal back in a second before engaging the clutch. It's weird but you do get used to it. I'll probably have a hard time when I go back to a normal non drive by wire manual. I notice everything is slow on the jeep. When I want to just tap the horn to let someone know to go if they miss the green light it doesn't even respond. I gave up after honking at a couple of people for longer than expected because I had to hold the horn longer. Don't want to look like a jerk.
Did the same thing in my si(before I tuned it) it's just a drive by wire thing, I just drive it like normal, the slight increase in rpm can't hurt the clutch that much, it's not like there's a load on it, it's just floating down slowly
