Engine RPMs @ 70 mph for 2014 JKUR with 4:10s
Well I can say my Sahara with 3.73s and 32s would turn about 2250 at 70 so at 2500 I'm thinking you got 4.10s. IMHO
Maybe I did get 4:10s. It was ordered with the max tow package. I posted a picture of my dashboard @ 70mph. In the picture you can see the tach @ 2500rpms.
Thank you for your input.
If you want to know for sure, regardless of what's on the sticker or build sheet, do this:
Jack one front tire off the ground.
Put a chalk mark on the tire and the drive shaft.
Rotate the tire by hand 2 complete revolutions while counting the drive shaft turns. The number will be your gear ratio.
A little less than 3 and 1/4 turns will be 3.21 gears.
About 3 and 3/4 turns will be 3.73 gears.
A little over 4 turns will be 4.10 gears.
