Engine related issues at 50,000 Miles
#51
Originally Posted by snopro269
Anyone with 2010 wranglers having any oil consumption problems? I currently own a 2010 Rubicon with only 4200 miles on it so far and my cousin is looking at buying a newer used one.
#52
Originally Posted by Scastlet
Mine engine had to be replaced at 10,000 miles for oil problems. It's a 2010 black unlimited islander
#53
Did the dealership ever say the reason was?!? Do you use synthetic oil or OEM?
#54
I have a 2010 with 37,000 miles on it. Yes 37k. 100 miles, 5 or 6 days a week to work n back. Anyway, no oil consumption or water leaks. I did just start gettin some knockin for a sec when I start it cold that bothered me. 20 to 30 degrees right now though and I do use mobil filters so I might try something different next time. Mobil 1 syn 5w20.
#55
#56
#58
49454, was smelling antifreeze after driving to and from work. Got on the Forum and did a search, finding lots of references to leaking water pump. Crawl under the Jeep after I got home and could see signs of said leak. Called dealership, described the leak and he said bring it in tomorrow, it's covered under lifetime power train warranty (called me back shortly to say pump was on national backorder, bring it in next week). Replaced water pump and made sure the k13 recall didn't affect my Jeep. Gotta live the warranty!
#59
2008 Jeep Wrangler Shara Unlimited
Out of the blue my engine started knocking at 52,000 miles. Took it to the dealer and they told me it was out of oil and that I needed a new engine block. I did purchase an extended warranty for around $700 that covered it,
provivded that I had records of regular maintenance. I provided my oil change records to the dealer, (mobil 1 synthetic every 6,000 miles), and they are currently putting in a new short block. Lesson to learn here, get a warranty and
make sure you do regular maintenance and hold on to the records.
Question, how can this happen if there are no signs of leaking oil, no bad exaust, and no warning light on the dash? This sort of problem should be fixed by the dealer with or without a warranty!
