engine clattering and "HOT OIL" warning
I have brought to the dealers attention the last oil change the clattering noise the engine makes when under strain, normally say driving on the beach. 2 times now I've got the "HOT OIL" warning while driving on the beach also. Almost sounds like when you ran low octane gas back in the day in something requiring premium. Any thoughts?
I don't get any engine clattering but have had the "HOT OIL" light come on once while driving on the beach. Sand wasn't really that thick either and I was moving along pretty good (around 3k RPMs). Is this just the result of the shitty engine? I have a 2011 BTW so no Pentastar.
The clattering is most likely the engine pinging from being overloaded at too low an rpm.
Sand really taxes the drive train. It's just hard to move through it.
The hot oil warning is for the transmission fluid.
Get an aux transmission cooler.
Put it in 4lo, "D", O/D off, as much as possible. This will allow the transmission to get into 3rd, where the torque converter can lock. An unlocked torque converter generates a LOT of heat.
I would be willing to bet you were in 4hi on the beach.
Nailed it
If you drive on the beach, without a doubt, get a transmission cooler. Since I believe they were added in 2012, you wouldn't have one and it is a good investment. I drive on at Assateage National Seashore in Maryland and I think it was three years ago? I burned up my transmission. Luckily it was replaced under warranty but definitely a headache and a half.
The recall to get the "HOT OIL" indicator had just come out so I took it in for that and a few other things and the dealer "said" they installed it. The next weekend when I was on the beach, no indicator and the transmission was finished. I was an unhappy camper and laid into my dealership.
Since, I have installed the cooler and haven't had a problem since. Definitely worth it.
This is the write-up I followed with the exception of the mounting of the cooler itself
https://www.jk-forum.com/forums/show...mission+cooler
