Electric Disconnect Idea
(If this isn't in the right category, my apologies)
I'm getting a set of sway bar quick disconnects for my Rubi. I was thinking with those that would render the electric disconnect fx useless right? If so has anyone or is it possible to use that switch and wiring for something else, like say rock lights?
Ideas? Thoughts?
Ideas? Thoughts?
Could probably be done.... My only concern would be how that switch is tied into the factory computer and logics. It has to talk back to the computer to acknowledge if it is connected/disconnected so i would imagine it is more than a simple switch circuit. Guessing you would need to trace it out and jumper the right wires so the computer thinks it is connected all the time. May be easier to add daystar lower dash panel and nice labeled rocker from otrattw. Just my thoughts.
Ideas? Thoughts?
Ideas? Thoughts?
Sent from my PG86100 using Tapatalk
