E-brake indicator coming on when e-brake not engaged
E-brake indicator coming on when e-brake not engaged. Has been happening quite often usually while I am driving. It eventually turns off but will come back on later... Any ideas on a solution?
Assuming the switch is not maladjusted:
If the light stays on when the parking brake is off, it indicates a possible brake system
fluid leak or low pressure level, or some other brake system fault has been detected.
