Dual Top Question
Old 03-04-2011 | 03:23 PM
timebandit's Avatar
Default Dual Top Question
Forgive the stupid question, but my manuals are still on order from the dealership.
My Rubi came with dual tops. I pulled the rear seat out since I don't have kids and could use the cargo space. However, the big burrito soft top is right in the middle of the rear access area. How do I remove this assembly to give myself room to put larger items in the back?
Pic for reference:
Thanks!
Old 03-04-2011 | 03:42 PM
cjsmith's Avatar
Pic for reference:
Thanks!
You have to take hard top off to remove soft top then put hard top back on,,,,,,that's what I did
Old 03-04-2011 | 04:28 PM
I bought in January and just lived with it till spring. Hung the HT in the garage and then figured out the ST.
Old 03-04-2011 | 07:17 PM
Weeds's Avatar
The way I removed my soft top from the inside was:
Remove the front panels;
unbolt the hard top from the body;
get inside the jeep and lift the top with your back while wife, gf, or who ever pulls the soft top out the back;
almost forgot, open the tailgate.
Good Luck!
Old 03-04-2011 | 07:19 PM
Paws's Avatar
Good Luck!
x2 on this. but I had a buddy lift the hardtop up from inside while i pulled the softtop out.
Old 03-04-2011 | 07:23 PM
timebandit's Avatar
Thanks for the suggestions!
Where do I disconnect the soft top at inside?
Old 03-04-2011 | 07:29 PM
Bad_CRC's Avatar
there are 4 screws, one on each bracket that need to be removed to remove the top.
You will also possibly want to remove the brackets themselves. I leave mine in, but many people take em off each year.
Old 03-04-2011 | 08:24 PM
Rubichronic's Avatar
There should have been a DVD in your Handbook that came with the jeep. It is basically the same info as the manuel you are waiting for. Just look through the info about Duel tops/Soft top removel. It took me about 20 minutes to do it, from start to finish.
Old 03-04-2011 | 10:21 PM
timebandit's Avatar
Handbook? What handbook?
I got zilch.
Old 03-04-2011 | 10:49 PM
ToolManTimTaylor's Avatar
https://www.jk-forum.com/forums/show...rd-Top-Removal
Quick Reply: Dual Top Question
