Driving the 6 speed manual
#43
By having the clutch down all the time when idleing, you will prematurely wear out the throw out bearing. I'm always on neutral when I'm not moving, period. It only takes 2 seconds to shift into 1st and start moving.
#45
On the shift knob there's a diagrahm that might help.
#46
#47
http://en.wikipedia.org/wiki/Clutch_...ing_the_clutch
#48
that my friend is called riding the clutch...not a good habit.
That IS NOT riding the clutch and it WILL NOT wear the plates since you are fully depressing the pedal, the clutch and pressure plate are not in contact with each other. Worst case is throw-out bearing wear and that is not an expensive part but I doubt even that would result.
Don't worry about this nonsense, drive it how you are comfortable. One dip in the mud will wear plates and bearings far worse than holding the pedal to the floor at a light.
#49
With that said, you can wear the springs faster if you hold the clutch in like that. Generally, you don't want to do it.
#50
I shift about 2500 when going lazy and economical, 2-4k most other times and 4-5 when I want to keep it on the peak of the torque curve.
Somewhere between 5200-6K it seems to limit out at times.
