Door stuck
WOOT!
Mine have been stuck a couple of times. No problems since I started using the anti-seize.
I q-tipped it into the hinges then painted the pins and the threads on the nuts
had the same problem with the rear doors. decided to finally try taking them off 2 yrs later as the kids are now old enough (almost) to trust going doorless. used a piece of 2x4 under the door and a floor jack to gently push it out of the hinges. had to step on the ace slider to drop the body for one of them and suddenly had to grab the door before it fell onto the asphalt. good thing i had the window open and managed to get an arm in there and save it .. made sure to grease them up nice afterwards
If you wiggle the door back and forth as your pulling it helps to get them off. Before you put your doors on take a little grease and put in the bushing on the hinge that will help to make it easter the next time you take them off
