Door hinge bushing necessary ?
I finally succeeded in removing the doors on my JKU. 2 years of winter Canadian driving made them very tough to remove.
While doing so, the driver door bushing were completely shot. I had to remove the bushing of the driver side door. I lubricated all the pins with lithium grease and reinstalled them.
Do I need to reinstall new bushing ? Are they mandatory or should I remove them all ? What is the drawback of running without them ?
Thank you
Thank you
Thank you
Thank you
You're probably ok for the very near term but I would replace the bushings asap.
Consider the upgrade to delrin bushings. There are several threads about them on the forum.
Also, take a good look at the alignment of your doors. There may be other reasons for the difficulty removing them.
Originally Posted by Biggy
Check out Magnitude Engineering for replacements that should last alot longer the oem ones
