Door Check/Limit Strap Replacement
I've searched for hours to no avail. Has anyone had to replace a door check/limit strap and have a part number? The hooks are in the parts diagrams but can't find the strap. Thanks for the help.
Just google 20xx wrangler door limit straps unless you're specifically looking for OEM.
Here's one from Warrior...
WarriorŽ - Jeep Wrangler 4 Door 2014 Door Check Strap
Just google 20xx wrangler door limit straps unless you're specifically looking for OEM. Here's one from Warrior... WarriorŽ - Jeep Wrangler 4 Door 2014 Door Check Strap
The fronts on my 08 are about 7.5 inches on the front doors and 9 inches on the rear doors. That's from the loop on the door to the end of the limiter (not including the wire harness that extends beyond the limit strap).
I bet you can make them out of paracord. I'd do that if I could but I can't find a specific video to show how to get the loops proper for a door strap. It happens to be the one jeep "how to" that I can't seem to find.
I had to replace the ones on the '13 JK my daughter drives as the prior owner cut the wires off instead of just looping them back and zip tying them in place. Make sure you pick the corrct ones before you buy them. I searched the net for hours, thought I had the proper parts then called to confirm only to find out that I was wrong. You really need to match using your vehilce vin to be sure and I called a online supplier that turned out to be a dealer in NY but they were extremely help and had great pricing
