Does anyone hear like water or fluid sounds inside their JK?
Old 02-24-2011 | 09:58 AM
ToolManTimTaylor's Avatar
Like as in water sloshing when taking off? I.E Overhead? Got your hard top on? Check your overhead panels for water INSIDE them. Many have cracked from overtightening the hand screws and water is allowed to enter the panels.
Old 02-24-2011 | 11:41 AM
Scrambled's Avatar
Originally Posted by 4 Jeep Family
If you have a hardtop, one of the front roof panels can fill with water. I have a 2008 Rubicon 4 door and my passenger side panel filled with water. I could hear it slosh back and forth. Take them off and turn the windshield side edge down and shake them, water my come out, if it does, the panel is defective. Under warranty, get new panel. No warranty, find the seam where the water went in and seal it.
X2 check your freedom top front panels.
Old 02-24-2011 | 04:00 PM
JKU's Avatar
JKU
thanks!!!! ill try it all!!!!
Old 03-05-2011 | 06:27 PM
I have water in my hardtop. As soon as it warmed up I could hear it sloshing around hopefully the dealer will replace it?
Old 03-05-2011 | 08:57 PM
wasntborn2follow's Avatar
I would check the coolant level and the waterpump.. could be leaking
Old 03-06-2011 | 08:33 AM
kingteddybear's Avatar
X2 what he said. Seemed to be a somewhat common post about a year ago. Just pull the panels off and give them a shake.
Old 03-06-2011 | 01:05 PM
TINMAN080's Avatar
(1.) The freedom panels are built-up from inner and outer panels. A 3/16'' hole is left open along one edge of the inner panel for condensation to escape. If your gaskets don't seal the outer edges of the freedom tops well and your tops have pinholes in the edge where they are bonded together water will enter the tops and slosh. Remove the sloshing top, hold your finger over the hole in the edge and turn the top very slowly, watching the edges closely. The water will leak out the same place it leaked in. Once you have found the seeping area, drain the top thru the vent hole. Once the top has dried use a non-silicon automotive body seam sealer and work the sealer into the leak area from the outside with your finger. Very easy to do this water leak repair with excellent results.
Old 03-06-2011 | 01:12 PM
TINMAN080's Avatar
(2.)If doing wheeling in the mud, many times your door drain holes will clog up and the door will fill up with water. Squat down and run your fingertips along the bottom of the door and you will feel the holes. Clean the holes by running a small screwdriver up thru each hole and allowing the water to run out the bottom of each door. Rinse the door by running a non-metallic object slightly between the glass and the black outer weatherstrip at the bottom of the window, and allow water to run from your hose into the door. Your doors are designed to have water run thru them, entirely normal.
Old 03-06-2011 | 01:18 PM
TINMAN080's Avatar
(3) On your hardtop the tailgate window can leak and allow water into your jack storage area. If the window gasket gets DUSTY and the window edge is dirty the tendency for this leak to happen is high. Raise your window, clean the window edge and the weatherstrip gasket and then apply a silicone paste lubricant to the gasket.
Old 03-06-2011 | 02:03 PM
JKU's Avatar
JKU
Thanks for all the useful info, went to the dealer and im waiting to get new tops..
Quick Reply: Does anyone hear like water or fluid sounds inside their JK?
