Disconnecting the swaybar
Old 01-09-2010, 06:10 AM
PG-JKU's Avatar
Default Disconnecting the swaybar
Has anyone disconnected the stock swaybar by just removing the bottom bolts and holding the connector up with zip ties or something?
How long does it take, especially to reconnect? And is it advisable to wheel in this configuration?
Thanks!
Old 01-09-2010, 06:12 AM
GoodysGotaCuda's Avatar
Yes you can, it can or can not take longer depending on what style of quick disconnect you are comparing it to. Get you a set of gear wrenches, take you a couple minutes for both sides.
Old 01-09-2010, 06:17 AM
Tweakecho's Avatar
Just ensure it is clear of any moving parts, this is how i do disconnect, it is very simple remember to reatach before highway use or the Jeep will be unstable. My friends have quick disconnects not sure what brand but it does not seem to much quicker. Fraction of a minute at best.
Old 01-09-2010, 06:22 AM
PG-JKU's Avatar
Thanks guys, that's good news.
Old 01-09-2010, 07:19 AM
TDJK's Avatar
Default sway bar
would there be a video or pics on how to disconnect it?
just curious, havent done it yet
Old 01-09-2010, 07:31 AM
sclan's Avatar
here you go. this write up uses a bungie cord to hold up and out of the way, but still shows how to disconnect
https://www.jk-forum.com/forums/jk-write-ups-39/manual-swaybar-disconnect-non-rubicon-models-6167/
Old 01-09-2010, 07:51 AM
Flagjeep's Avatar
Thanks!
You will notice a big difference when wheeling disconnected. Try it and see what you think! Drive down your favorite trail while connected, go back to start, disconnect, and drive trail again to compare the ride and handling differences. When reconnecting, just make sure you are parked as level as possible to line everything back up for bolting. I purchased the Teraflex Quick discos and really like them, you can just use wrenches though.
Old 01-09-2010, 08:30 AM
PG-JKU's Avatar
Found the writeup and more. I thought I had searched first but missed it completely. I'm a moron.
Can't wait to try this.
Old 01-09-2010, 09:22 AM
SWRUBI's Avatar
Is there any possibility of unseating the springs while disconnecting the swaybar? JKS has what looks like a decent offering for quick disconnects for $79 bucks.
Old 01-09-2010, 09:25 AM
PG-JKU's Avatar
I don't think you can use the JKS disconnects without a lift.
Maybe that's just the "quicker" version.
Quick Reply: Disconnecting the swaybar
