Difficulty starting....
Old 12-20-2007 | 12:08 AM
pezeveng319's Avatar
Default Difficulty starting....
Hey, has anybody's jeep had difficulty starting?... my jeep seemed like it was having difficulty starting twice so far... the ignition kept trying till eventually it fired up.
Old 12-20-2007 | 01:38 AM
07rubi07's Avatar
I had this problem after i powerwashed the engine. Stupid me thought it would be a great idea to pull the hood back, stand on the bumper and hose it down.
I was told that it was my cam shaft sensor. The dealer is replacing it for me tomorrow under warranty.
Old 12-20-2007 | 05:29 AM
sbaglin's Avatar
Yes, this has happened to me a least 5 times since I've bought by Jk back in September...I'm wondering if its time to take it into the stealership...it always starts, just sometimes takes a good 2-3 seconds longer than usual
Old 12-20-2007 | 09:18 AM
Henri's Avatar
Originally Posted by N2rock
There is a TSB for this problem- http://project-jk.com/jeep-jk-tsb-re...-camshaft-gear
I took mine in to the dealer 2 weeks ago for this and it has not happened since. Go to the link above, and print out the TSB's pdf file, and take it to the dealer with you.
Same here. I had the TSB done, replaced the camshaft sensor and now it fires right up
Old 12-20-2007 | 09:58 AM
Ohh yea this seems to be exactly what is happening... Thanks alot guys!
Old 12-20-2007 | 03:14 PM
ZidJeepMan's Avatar
if it takes a few seconds to fire up after you let off the key then its NORMAL as described in the manual, if it doesn't fire up after an attempted start cycle and you need to recrank it a few times then its the TSB. But the extended crank for maybe a second or two after you let go of the key while starting is normal. The manual describes this.
Mike
Old 12-20-2007 | 03:16 PM
spencenaz's Avatar
Yup, this fixed mine too. Seems like this affected a lot of JKs. Makes you wonder how many OTHER things were not installed correctly by the factory.
Quick Reply: Difficulty starting....
