Diff Fluid Change
#21
#22
The dealer told my wife the same thing when she took the jeep in for a recall. They checked everything and went thru my maintenance log and noticed it was due for the diff. fluid change. They said they would be happy to do it and would only cost around $250! Luckily she remembered i had already bought the fluids and planned on doing it on the next oil change. If you do do it yourself make sure you get the additive for the rear-end which is only available thru the dealer as far as i know. It will cost between $4 and $10 depending on the mark up. Also the plugs have magnets on them to catch any metal shavings from normal wear. If you do notice any large shavings you may want to take the cover off and inspect your gears.
#23
#24
You'll need a partner for that last step. And although that step isn't strictly necessary, it does make the whole process much more rewarding
#25
yes, thats the additive Im talking about. I know for sure mobil one has it in it and Im pretty sure Royal Purple and Amsoil does too. Check out their websites and look up gear oil, it will tell if it does or doesnt have the limited slip additive.
#26
I don't know why you would pay someone when it is an easy do-it-yourself job. For a simple fluid change, just use a 3/8" extension and ratchet to remove the drain and fill plugs. If the oil looks murky or has strange particles in it, then just take the diff cover off and clean/check the inside. You are paying someone 45-90 bucks an hour to do something anyone can do with a drain pan and simple household tools. You can take the old oil to a Walmart or some auto parts stores take used oil. If you do it yourself, you can ensure quality products go in (I use Royal Purple), instead of the cheap stuff. 3-containers of Royal Purple @ $11.99 plus a small tube of sealant (if you take the covers off) is around $40. Plus you can learn something and be sure everything is torqued properly. If you use the right products, the warranty will not be voided. They can only void the warranty if you do something stupid and they can prove neglect, like leave the plugs off or forget to put oil in it.
#27
It says in the manual "Trac-Lock" requires additive
#28
right..... which most synthetics already have in them......sometimes you will still get some chatter from the rear, so you might have to still add some of the friction additive, but most of the time the additive in the synthetics is enough.
#29
Its crazy how much they want to do it. For the price the dealer wanted, I got Solid Diff covers, lube lockers, and lunch.
#30
Just keep your receipts and you'll be fine. You should consider changing dealers if you think yours is like that. The fact of the matter is that if they want to give you crap about the warranty then they'll find something.
