Did I accidentally disable controls on steering wheel?
Most of the steering wheel controls on my 2011 4-door Rubi stopped working. I noticed it this morning when starting up & going to work. I think the only one that still works is the one that turns cruise control on/off). The others - reset, cycle through mpg/temp/etc, change channel/volume, etc. - are dead. Is there a lock function that I inadvertently hit?
Update: Problem solved. Pulled / inspected / re-inserted every fuse. No bad fuses but problem went away. Probably either a fuse that wasn't seated properly, or a software glitch that was reset by pulling fuse.
Problem solved. Pulled / inspected / re-inserted every fuse. No bad fuses but problem went away. Probably either a fuse that wasn't seated properly, or a software glitch was reset by pulling fuse.
