Dealership cut my fenders...
Old 08-05-2011, 02:19 PM
Matt08jk's Avatar
I used to own a 08 but now I have a 2010.
The 2010 was built in June 2010 but it has fender liners already formed to avoid the brake lines,.. but they forgot to install the fender bolts.
I had to buy those myself and install and they have the same gap that you have. I checked a few 2011's on the lot and same deal.
Old 08-05-2011, 02:38 PM
Hound's Avatar
Wanted to chime in on this as well. Just had mine done on Wensday, finally had a chance to inspect.
Drivers side:
Name:	2011-08-05 17.22.25.jpg
Looks fine, I can deal with how it's cut.
Name:	2011-08-05 17.22.39.jpg
Further inspection reveals the went at it was a gigsaw.
Passenger side:
Name:	2011-08-05 17.22.54.jpg
Looks fine but you can see where the fender sagging had rubbed against the frame
Name:	2011-08-05 17.23.02.jpg
Close up of the rubbed area
Also my outer fender seems pretty loose now as well.
Name:	2011-08-05 17.22.29.jpg
Old 08-05-2011, 04:05 PM
itasor's Avatar
Wow, they only cut about .5" off of my liners...just enough to make sure it doesn't hit the brake line. Some of these pics look like they went a little overboard!
Old 08-05-2011, 04:26 PM
headhog's Avatar
Wow, I just bought a 2009 JK X and found this recall was not done. After reading some of these horror stories, I'm going to think twice about getting this done. I really hate dealers and their service departments and this is just the icing on the cake. Over the last 30 years I've had too many bad experiences with dealers. From cars to trucks to motorcycles I avoid them at all cost.
HH
Old 08-05-2011, 04:32 PM
fadeout's Avatar
laughed at this TSB went outside noticed that it had rubbed the slightest bit but nothing that was affecting performance and proceeded to take a pair of Fiskars and trim it myself, took all of 5 minutes and looks a Hell of a lot better than what some of the service guys have done. Can't believe that someone would bother to pull down the whole fender and chop off over 3 inches for this...
Old 08-05-2011, 04:39 PM
Merlin4979's Avatar
HH
Just do it yourself. Mine was done when my gas tank was being replaced. It looks like they let a palsy victim go at it with a weedwacker. I was pissed.
Old 08-05-2011, 04:49 PM
headhog's Avatar
I will be taking this advice and trimming this up myself tomorrow.
Regards,
HH
Old 08-05-2011, 05:21 PM
mkjeep's Avatar
Originally Posted by Boosted
As mentioned, the cut is to provide clearance to the brake lines to prevent them from rubbing and eventually cutting into them. The bolt that you are referring to is designed to allow the inner liners to have some movement to reduce noise. Both are normal and as intended per the service bulletin.
Movement would increase noise. My bolt they put in holds it flush.
Old 08-06-2011, 04:38 AM
MontaukRubi's Avatar
You dont know anyone with cerebral palsy do you?
Old 08-06-2011, 05:37 AM
dogsonparade's Avatar
I brought mine 07 X in before I was doing too much modding myself. I sat there for a few hours while they did it. I could have done all that stuff myself and made it look 10 times better. I also had the fender rub through the metal part on the brake lining...
I don't like when other people work on my rigs (unless it's far beyond me)
Quick Reply: Dealership cut my fenders...
