Dealer says 1 of 3 problems for my locker not engaging. What do these mean?
Front locker on my 07 JKUR will not engage. Had it at the dealer getting the TSB's up to date (I just bought jeep). Told them to check it out, but not spend to much time on it. Said they looked at it for 30 minutes ($40). And the wrote the following on my paper work:
"Locker is not engaging front locker ino, checked TIPM module for codes- none, checked fuses/relays for lockers- OK, checked ground circuit Z905 at front locker solenoid. Good ground, no power signal at solenoid circuit T-520. Will need more further diagnosis to determine if cause is wiring issue circuits A104, T520, or TIPM fault"
The guy I bought this from had done the locker bypass switches front and rear. Rear works fine using bypass or factory switch. Front does nothing with either switch (yes, 4 lo, lock click button twice).
Any ideas? I know wiring and jeeps, but don't know all the dealer lingo/tech talk.
What and where do I test?
Thanks a TON for any and all help!
Anybody have more knowledge on what "wiring issue circuits A104, T520, or TIPM fault" is?
Hoping somebody has a service manual!
Thanks for all the ideas, keep em coming! :-)
I am totally frustrated.
