dealer saying engine is dead
Old 08-05-2014, 12:49 PM
DadsCJ's Avatar
Originally Posted by cyzz
It turns on even drives tail pipe wasn't in water just front end!
Okay, I don't understand what they mean by Dead?
It runs right?
If it squeals, clean the front pulley's off and check to see if they need to be replaced.
Same with the belt and alternator, although I just cleaned mine and it worked.
Old 08-05-2014, 03:22 PM
cyzz's Avatar
I keep asking them they just say I need new engine and that there is alot of water in engine I will have to just go and pick it up because they are being to blunt
Old 08-05-2014, 03:56 PM
Jade_Monkey07's Avatar
Ok, but so are you. People here have asked what else your issues are. Describe how and when it stalls. Use your words
Stay muddy my friends
Old 08-05-2014, 04:49 PM
kmrtnsn's Avatar
Originally Posted by myrojk
If it stalled in the water mud it can come right in the tail pipe
sent from the bottom of a water hold and didnt lock the motor
No, it can't. I'm sure that if water hydrolocked his motor it came in the normal way, right through the airbox.
Old 08-05-2014, 04:58 PM
myrojk's Avatar
OK you can believe that and when it happens to you to you can come back and say I was right
Old 08-05-2014, 04:59 PM
Billbikes's Avatar
If the engine runs, maybe you can start by what symptoms you were experiencing that caused you to take it to the dealer. Sounds like to me you fouled your clutch, maybe even sucked some mud into your cooling system through your reservoir(don't ask me how that happens, I've just seen it a few times on here). If you had Mud and water in your engine other than that it really wouldn't run.
Old 08-05-2014, 07:50 PM
tjoff's Avatar
I think dealer is wrong here. Motor will not run if hydro locked. Hydro lock is from water on top of piston, water does not compress in cylinder and locks up and usually will bent or break a connecting rod. If water in lower end and motor running oil will be milky color and will register high(above the full mark) on the dipstick. If motor running don't think it is dead
Old 08-05-2014, 08:25 PM
Mountain Man Tim's Avatar
+5 troll points for the OP, this thread makes zero sense.
Old 08-06-2014, 03:37 PM
DadsCJ's Avatar
I agree, something isn't right.
I am out of here.
Old 08-06-2014, 03:58 PM
sillybubba's Avatar
i think it may be mostly the OP fault. Does not seem that intelligent to me.
Quick Reply: dealer saying engine is dead
