dealer saying engine is dead
Went offroading spotter said mud pit wasn't to deep went in and mud cam a little over bumper front wheels almost gone tried rocking my self out engine started s
A little more info would be very helpful to answer your question. By the sound of it, it sounds like you might have hydro locked your engine.
What info do you need it turns on stays idleing clutch sticks a bit don't know where the water would go through since mudd didn't get that much above bumper it's a 2014 jku
did you use your clutch
when you were in the deep water ? you are not supposed to use clutch on 6 speed when in water
if you stall or need to shift you shut off jeep don't use clutch just turn key while in gear 4lo any gear you select but you don't use that clutch/ that's about all I could say on this ! if you even used the clutch or not ????
The dealer should be providing you with specifics. Why is it dead, what caused it and etc. The gets in though the air filer. I have an aftermarket intake and went through some deep mud and it sucked up a lot of it and soaked my air filter. I'm lucky that's all that happened.
I asked and they say they don't know what's wtongthey keep saying there is alot of water in engine and mud and I asked how it got in and they said they don't know how it got in
sent from the bottom of a water hold and didnt lock the motor
