Dana 44 axle. rubbicon vs. non rubicon
Hi Everyone.
I need some basic AXLE info.
I'm building an '82 Scrambler and am considering using JK Rubicon Dana 44 axles.
How good are they? I've heard they're better than the models used in TJ or LJ Jeeps. Yes or no?
What's the difference in the JK RUBICON 44'S and the standard JK 44's ?
Any advise would be greatly appreciated.
Thanks.
Thanks.
The JK dana 44s are substancially beefier than the TJ axles.
JK vs TJ
spline count - 32 vs 30 & non rubicon JK
Inner pinion bearing dia - 1.625 vs 1.325
Outer pinion bearing dia - 1.310 vs 1.125
The front is similarly larger, though the front tubes seem to be its weakest link and is the same outside diameter as the TJ which is 2.5"
JK vs TJ
Rubicon D44 front has 30 spline inner shafts and 32 spline outers. It also has u-joints that are unique to the JK and are larger than the previous model D44 (760/297X joint) axles. The high pinion design makes this axle stronger than older low-pinion designs. The weak points are that the c-clips are still not full circle clips and have a tendency to fall out- leading to failure, and that the "inner c's" can bend with hard core use. Both of these problems can be remedied fairly easily making the axle a good economical upgrade in my opinion.
Rubicon D44 rear has 32 spline shafts.
Non-Rubi D44 rear has 30 sline shafts.
I suppose you do already know the JK axles are about 6 inches wider than your stock Scrambler axles? The JK axles also have a 5 on 5 bolt pattern as opposed to the Scrambler 5.5 on 5
On the other hand, I ran full width truck axles on my old YJ
