D44 axle seal leaking
Old 05-03-2012 | 10:12 AM
hoveyjk08's Avatar
So I looked at a parts diagram for the rear axle. And yes, the axle seals are on the wheel end and do not require acces to the carrier.
I still would need to remove the axles, hub assembly and then I will have access to the axle seal? Can you explain the process of replacing the rears in more detail?
Old 05-03-2012 | 10:22 AM
hoveyjk08's Avatar
Do I need to replace/remove the bearings to replace the seals?
Old 05-03-2012 | 10:53 AM
ronjenx's Avatar
You will need a press to remove and install the retainer and bearing.
Here is a link to a tool you will need:
http://www.harborfreight.com/large-bearing-separator-3979.html
Old 05-03-2012 | 11:01 AM
hoveyjk08's Avatar
Ronjenx do you have a write up on the process?
Old 05-03-2012 | 11:06 AM
ronjenx's Avatar
No. But, I have seen some threads that don't qualify as a write-up, but show what's involved.
Old 05-03-2012 | 02:44 PM
Infinity's Avatar
I don't have a write up on this, but I did this not too long ago.
Once I pulled out the axle, I used a grinder to cut off the retainer and factory bearing. I then slid the new ones on and used a large metal pipe (a friend had one just for this purchase) to persuade the bearing into place. Just took 2 or 3 blows to push it on like a slide hammer.
It cost me about 100.00 for the retainer, bearing, and seal. It also took me a few hours. Most of the time was spend cutting off one of the nuts from the retainer because one of the bolts spun and I couldn't unbolt it! You might call around. I might pay someone to do this next time if the price is reasonable.
Josh
Quick Reply: D44 axle seal leaking
