Crazy question but I will ask any way Freedom Panels
I am working on a leak issue and if I can't fix it, is there a what tight adhesive (maybe marine) for fiberglass?
I am thinking about making the two freedom panels into one true targa tap.
Seal them together, it will be a little bit of a pain to get it off but it should fix my leak problem.
Thoughts and comments are always welcomed from this forum.
Yep
I am working through a lot of the threads about leaks I am just thinking of something I can do if they don't work.
I am looking into Marine Grade Adhesives.
But I am hoping one of the other things will fix it.
I am working on this weekend.
The number one reason for leaks with the freedom panels is not flipping flat the little supports at the back - they should be down when installed without the back, but flat otherwise......I spent way too much time on that until someone pointed it out to me.... doh!!!
Originally Posted by OscarTheJeep
Do you by chance have a pic of what you're talking about? Is it that little 3/4" by 2.5" thing on the back of the panels?
The biggest thing I find is to get both panels down without locking them down, make sure they are seated well then secure the latches, then secure the knobs.
