Cracked front windshield....Did this happen to you??
#61
I finally got a chip in the fall. Got it fixed then this winter it started to crack. I guess a new windshield in the spring. Does anyone know if the 10 or 11 wind shield with the little jeep on the corner will fit a 07. I would not think the windshields have changed at all
#62
If you fill the gap between the glass and the top of the window frame with something, it'll go away. I use 1/2" or 3/8" round insulation from a home improvement store. I feed it in with a plastic bondo/fiberglass knife.
#63
Thankfully in Massachusetts windshields are covered by insurance. I think I am on my 4th or 5th one in about 80,000 miles. Last year, I had a new one crack a month after it was installed.
It seems as though anytime you get a chip in the black section of the glass, it's likely a goner. It may not crack right away, but likely will eventually. I had two chips (in separate windshields) in almost the exact same spot - under the drivers side wiper blade. Both cracked and had to be replaced.
I wouldn't say Jeeps are 'much' worse than other cars, but I do think they're a little more susceptible to to chip because they take a full on blow, vs a glancing blow of a more sloped glass found in other vehicles. Still, there is the aspect of (bad) luck too.
#65
Had my jeep for about one month before something smashed into the windshield on the highway, left a crack about an inch and a half long just to the left of the rear view mirror. It didnt spider during the summer, hoping it wont in the winter.
#66
I am just waiting for a windshield crack.
After over 4 years on gravel, I only have a couple of tiny nicks in it. They are not big enough to fill, barely perceptable.
Turned on the heat/defrost this morning with the outside temp at 1 degree. While holding my breath.
It is only a matter of time I think.
#68
Originally Posted by YJ207JK
Bought my 07 new and am on my third windshield. I guess that's just part of driving a Jeep with a high angled windshield.
#70
Originally Posted by hduplease
had my 09 windshield replaced, auto glass company gives a lifetime warranty on cracking from stress,
