Could anyone kindly post some pics about the Electronic Sway Bar system of JKRubicon?
Old 12-14-2007 | 02:44 AM
Cappi's JKR's Avatar
I know its kind of an old thread but, I have a question concerning these "Auto QD's"
Do ALL Rubicon's, 2 door or 4 door, come stock with this feature??
The reason I ask is, I just got back from checking out the 4 door Rubi that they tried to give me (instead of the one I ordered) and I really gave it the once over. Checking everything out. I crawled under the front end to get a look at the undercarriage protection and the sway-bars and sway-bar links. They looked pretty damn solid and exactly like what on my friends 07' Sahara (without that option).......didn't see any possible way they could disconnect.
Weird thing is, after looking at it for a good 3-4 min. I looked at the window sticker....It said that was one of the options.
Any input would be appreciated, Tony
Old 12-14-2007 | 04:47 AM
Windrocker's Avatar
So as Gunny asked above, when adding a lift is there any effect to the auto disconnect system?
For instance if a 2.5 inch TF BB was added would it still work? I would assume the links would have to be lengthened.
Old 12-14-2007 | 09:50 AM
nepatsfn's Avatar
There is no affect at all. Mine still works with my 2.5 lift. Just put your rear links on the front.
Old 12-14-2007 | 03:38 PM
CUOFFRD's Avatar
Default electronic sway bar
To disconnect the electronic sway bar disconnect you must be in 4LO and iuder 18mph, above that it will reconnect and also when you shift out of 4lo
Old 12-14-2007 | 03:49 PM
atomicmecha's Avatar
thats partly correct. The swaybar will disconnect in 4HI or 4LO.
Old 12-15-2007 | 05:01 AM
RubiconOrdie's Avatar
Default Rubicon Sway Bar
With a lift all you need is longer sway bar links, either new or by using the rear ones on the front.
It will disconnect in 4HI and 4LO.
As far as I know every Rubicon Model has it. (2dr and Unlimited) The motor is hard to see with the stock air dam installed.
Quick Reply: Could anyone kindly post some pics about the Electronic Sway Bar system of JKRubicon?
