Coolant temperature
So I've posted a bit about my engine running a little hot and was curious about the coolant temps. My Jeep is a manual, and I notice sometimes a smell comes from the grill that smells a little clutchy if that makes sense. I notice my coolant temp can go up to 220s when there's more traffic. Haven't had any drop in coolant levels which is good. But does it make sense that in traffic with a stick the clutch may get a little hot hence the temperature and smell? Are these numbers terrible?
Mine has gotten has high as 242...it's been to 2 different dealerships, both of which say the hottest they've seen it is 228. I sent one dealership a text last time then it got up to 237 and they said it was "normal."
I had my radiator replaced by the dealership back in June and it never got that hot before they replaced it.
Mine is a 2014 auto JKUR.
I am not convinced the engine should be running that hot. People report the temps continuing to climb after the fan comes on. I would think the temp should drop when the fan comes on.
Whether it's normal or not, the 3.6L engines don't seem to be failing due to high coolant temperatures.
Regarding the hot clutch smell in traffic, that is entirely possible. Repeated revving to get moving is the most common cause. The won'r raise the coolant temperature, though.
