Just wanted to throw this out since you're learning: If you're just topping up on the coolant, the engine doesn't need to be running. If you're refilling the coolant after draining it (like after replacing the water pump), then you would want to fill through the expansion tank and then start the engine to circulate the coolant to remove any trapped air. Keep topping up until it stays at the max line. Also check the level again after driving it the first time. (Be sure to replace the expansion tank cap before driving)
And NEVER remove the expansion tank cap if the engine is hot. Always wait for the engine to cool down. |
ummm NO! Please lets not give bad advice guys.... if you don't know don't post. you must have the engine warmed up to normal operating temp BEFORE adding any coolant. This is the only way you will know if your coolant is low. please read your manual. The coolant expands as it is heated and if you just add coolant when its cold you will overfill it. this will do two things. 1) make a huge mess on your driveway and around town as you splash coolant everywhere. 2) you could damage your cooling system by having too much coolant creating excessive pressure that may cause excessive wear on parts. (water pump, hoses, radiator, cap seals etc.) also only use MOPAR HOAT do NOT mix different coolant types, you will regret it.
Engine Coolant Level The coolant bottle provides a quick visual method for determining that the coolant level is adequate. With the engine idling, and warm to normal operating temperature, the level of the antifreeze/coolant in the bottle should be between the ranges indicated on the bottle.The radiator normally remains completely full, so there is not need to remove the radiator cap unless checking for antifreeze/coolant freeze point or replacing antifreeze/ coolant. Advise your service attendant of this. As long as the engine operating temperature is satisfactory, the coolant bottle need only be checked once a month. When additional antifreeze/coolant is needed to maintain the proper level, it should be added to the coolant bottle. Do not overfill. Adding Engine Coolant Your vehicle has been built with an improved antifreeze/ coolant that allows extended maintenance intervals. This antifreeze/coolant can be used up to 5 Years or 100,000 miles (160 000 km) before replacement. To prevent reducing this extended maintenance period, it is important that you use the same antifreeze/coolant throughout the life of your vehicle. Please review these recommendations for using Hybrid Organic Additive Technology (HOAT) antifreeze/coolant. When adding antifreeze/coolant: ˛ The manufacturer recommends using Mopart Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology). ˛ Mix a minimum solution of 50% HOAT engine coolant and distilled water. Use higher concentrations (not to exceed 70%) if temperatures below -34°F (-37°C) are anticipated. ˛ Use only high purity water such as distilled or deionized water when mixing the water/engine coolant solution. The use of lower quality water will reduce the amount of corrosion protection in the engine cooling system.Please note that it is the owner’s responsibility to maintain the proper level of protection against freezing according to the temperatures occurring in the area where the vehicle is operated. NOTE: Mixing antifreeze/coolant types will decrease the life of the antifreeze/coolant and will require more frequent antifreeze/coolant changes. CAUTION: Mixing of antifreeze/coolants other than the specified HOAT antifreeze/coolants, may result in engine damage and may decrease corrosion protection. If a non-HOAT antifreeze/coolant is introduced into the cooling system in an emergency, it should be replaced with the specified antifreeze/coolant as soon as possible.˛ Do not use plain water alone or alcohol-base antifreeze/coolant products. Do not use additional rust inhibitors or antirust products, as they may not be compatible with the antifreeze/coolant and may plug the radiator. ˛ This vehicle has not been designed for use with Propylene Glycol based antifreeze/coolants. Use of Propylene Glycol base antifreeze/coolants is not recommended. MAINTAINING YOUR VEHICLE 379 7 |
Originally Posted by daggo66
(Post 3632059)
Make sure you check your blinker fluid. If your coolant is low, then chances are that's low also.
Originally Posted by jk.bushwacker
(Post 3632920)
That being said, this is really the proper method when topping off the system as well as refilling after draining, so my previous advice was a bit flawed. |
I removed the cap on a hot engine when I was a teenager and still learning. You wouldn't believe how high that stuff shoots out of the radiator cap!!
By chance my head was not over the radiator or I'd have been badly burned. So lucky. |
Originally Posted by spartan99
(Post 3633328)
(Post 3633328)
By chance my head was not over the radiator or I'd have been badly burned. So lucky. Dangerous stuff. |
I dont know about you guys but my 07 has the orange dexacool coolant in the system. I had to add a half of jug of premixed orange fluid the other day for the first time.
Originally Posted by tribulation138
(Post 3633525)
For what it's worth the "yellow" G-05 looks reddish-orange in my JK, but it is now 5yrs old and getting flushed next week. (along with my 5 yr old brake fluid...) If it's the OEM fill it isn't Dex-cool (OAT) it is the G-05 HOAT. Chrysler switched to HOAT in 2001 (and just changed to a new, unique OAT for 2013). And if it is the OEM fill, it "expired" on you a year or two ago. |
