Continued Death Wobble
So I an issue with a severe case of death wobble about 3 months ago. Purchased a new Steering Stabilizer and got it installed. Late last week, the wobble started up again. Climbed up underneath the Jeep and everything appears to be nice and tight and the stabilizer looks brand new still.
Any suggestions or experiences anyone can share?
How many miles on your tires? And are they the goodyear wranglers? I had DW that started around 40,000 miles off and on until 70,000 miles. I purchased cragar rims and new tires and the problem is completely gone. The stock tires that come on JKs are garbage
I hope you figure it out. DW is a huge headache.
In the meantime I also urge you to file a safety complaint here..
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
I was told by a seasoned mechanic that the front suspension of the new JK is flawed. He personally changed 6 trac bars in JKs in the last year. He said that any # of things can cause DW. before I got my tires he said that (due to my mileage) the tires were probably the culprit, then if not, probably the trac bar or any such combo. He was right on. I got new Kumho All terrain tires and problem is gone. I tried to induce DW by hitting all the notorious bumps that caused it, train tracks, sewer covers etc, I cant even induce a slight shimmy. I am amazed that tires could cause such a violent shake!! My DW was so bad it would shake my jeep right out of gear!! (6spd) no kidding!!!
funny you mention this.. I must have got a decent set. While I had some DW for a lil bit.. it went away after I had everything checked out multiple times. My tires actually lasted a freaking 75K. A tire shop is actually offering to buy them from me. They are coming off tomorrow.
death wobble
I had the death wobble. CHecked everything for tightness and wear. I checked the ball joint by grabbing top and bottom and there was no movement. Then I put a pry bar under the tire and pried up. You could see a SLIGHT movement in the ball joints. Replaced them and no more death wobble. If you replace your ball joints, don't skimp on them and put factory equivelents. Spend $600.00 and get the best.
