Code help!!!!!! Please.
P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
Theory of Operation
The engine coolant temperature sensor is a negative temperature coefficient thermistor-type sensor whose resistance varies inversely with temperature. At cold temperatures the sensor resistance is high so the voltage is high. As the coolant temperature increases the resistance decreases and the voltage becomes low.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ECT SIGNAL CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ECT SIGNAL CIRCUIT SHORTED TO THE SENSOR GROUND CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]EXCESSIVE RESISTANCE IN THE ECT SIGNAL CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ECT SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
Theory of Operation
- When Monitored: With the ignition on. Battery voltage greater than 10.4 volts.
- Set Condition: The PCM detects that the Engine Coolant Temperature Sensor input voltage is below the minimum acceptable value. One Trip Fault. Three good trips to clear the MIL. The MIL and ETC light will illuminate if equipped.
[TABLE]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
