Clutch in water question
Ok, this is probably a newbie-type question, but my wrenching background is motorcycles, which have totally different clutch systems...
When preparing for water crossings, we extend our breather hoses on the diffs, tranny and transfer case, but why is nothing done to protect the clutch to allow shifting while fording?
Isn't there a way to cover or relocate the clutch venting to a higher spot?
Again, I don't really know how auto clutches are setup, so maybe there is an obvious answer to this. I just need some enlightenment.
Nope, no way to seal the clutch to keep the water out. With a clutch, either stay out of deep water (my suggestion after toasting a TOB and pilot bushing the last time I did it), or don't shift.
This is a pretty cool read of the old military CJs and water fording.
Follow-up question
Ok, so say I'm in water in 4-low, moving in 3rd gear or something, and need to downshift to go much slower or creep along for some reason...
The JK will start without the clutch in 4-low. So can I shut it off, change to 1st or 2nd gear without the clutch, then restart and continue on my way? Or will I be unable to restart because water has entered the muffler while the engine was stopped?
My suggestion would be to go into water in 1st gear in 4-low. There shouldn't be any reason to need to go any faster than that in deep water (as going faster tends to cause waves and bad things to happen). I have had a lot of success in 1st and 4-low during water crossings. Granted when I felt like I was going to get stuck I have bounced off my redline during parts of many crossings, but why else have a red-line if you aren't going to use it 4-low and 1st should still also allow you to go fast enough to keep up the momentum to not get stuck in the mud if its a deep water/mud crossing. Remember slow and steady wins the race
So you can start the JK in gear if in 4Low? I certainly know that in 4High or 2High you need to depress the clutch first to activate the starter; or are you saying that depressing the clutch when the motor's off won't risk clutch damage if the tranny's submerged?
Yep, in 4-low you can start without depressing the clutch.
The ratio is low enough that the starter can fire the engine and get the wheels rolling a bit and on your way.
You don't want to press the clutch while under water, regardless of motor running or not. It will suck water in.
wow! cool article on military CJs. they eventually got those jeeps to be able to ford 74'' of water! now THAT'S water fording!
and for clutches, they used positive crankcase pressure to pressurize engine & eventually bellhousing. driver had to insert a drain plug at the bottom of bellhousing before water crossing. ... and put ob his bathing suit I guess!!!
BTW, there are many books, manuals, & web sites that tell us techniques for off roading, like how to use the started to get over rocks insteat of riding clutches & tips like that. I'd suggest reading them. Mark Smith from jeep jamboree fame has one they give out with each jamboree registration. that was a good read. even the owners manual has good tips.
enjoy!
enjoy!
