Clutch pedal return spring broken
Is this a big deal? Concerned that this will put stress on the "functional" component of the assembly... My understanding is that this is a "return" spring as opposed to "assist". The spring provides some resistance and pushes back against the drivers foot operating the clutch pedal. Is this correct?
The pedal is now just dangling when not "in use". I can wiggle the pedal from side to side (dangle it, like something else I own...). Is the spring meant to prevent this dangling?
I cannot find a diagram, so I cant find parts. What I did find is that the spring may be the cause of some squeaking issues.
In the image, the red circle is the spring in question. My concern is with the hydraulic(??) component circled in blue... is it gonna break?
2014 JKU
Thanks for your time.
2014 JKU
Seems useless
2014 JKU
2014 JKU
It may allow the throwout bearing to ride more on the clutch pressure plate fingers. This will cause faster wear on the bearing which needs transmission removal to repair. I personally would get it fixed.
