clutch makes clicking noise
Mine made that noise for a over a year. It was a rattling kind of sound that you could hear right at 2500 RPM. It would also sometimes do it if I had been driving for a while, put it in neutral, and let the clutch out (it was like a ticking sound that went away if you messed with barely pressing the clutch pedal down). It finally started making that noise constantly, followed by some mean sounding metal-on-metal. I just got a new clutch this week and no more noise.
The tickin when pressing the pedal in and out is the slave cyliner on the side of the tranny housing. I got under the jeep and had my gf press the clutch in and out. You can see it moving. The part is bout $80
wow!
I'm pretty sure that I'm having the same issue ,, I have 2011 sport. 1300miles
I thought its started after i went throw a pretty deep mud puddle.. but that's really when i started listening to every little thing .. I know that i have mud under my jeep , how much do you think this will be a problem..
it only really does it when its warmed up a little...
Had the ticking on my '11 Rubicon around 3k miles. The ticking was pretty loud... Barely pressing the clutch made it go away. Dealer replaced the throwout bearing at about 4k when I brought it in. I found this issue in another thread and was able to feel confident taking it in as to what to expect. Had to speak with the shop foreman to diagnose it.
Clutch clickin when engaging and disengaging
for all the 6 speeds out there; has anyone noticed a clicking noise while engaging the clutch? When I slowly stick the clutch in I can hear a "click click click" I noticed it today when I had the doors off. Also I can feel it in the clutch peddle but just barely. It does it when the Jeep is both on and off. I'm gonna try and take it in under warranty but I wanted to check if anyone has experienced this before and maybe a little heads up before I get to the dealership.
Thanks to everyone in advanced
Originally Posted by LincolnSmith
my 2013 jeep wrangler sahara is doin this exact thing to. Doesnt effect the way i drive but i can really notice it.
If it is a squealing clicking noise that matches the RPM while you have the clutch peddle all the way down, then your TOB is going and needs to be replaced.
If it is a squeak/click that happens when you move the peddle in and out whether the Jeep is running or not, then it is the slave cylinder, and all three slaves cylinders I have had on my 2013 have done it. Some say there isn't enough grease on the end of it where it engages the clutch fork, but I greased the $h!t out of the last one I put in and it made no difference, also it is a pain to remove and put back in, so I just live with it.
Happy Jeeping!
The clutch disc center wore out and became loose on mine, for pics see: https://www.jk-forum.com/forums/jk-s...5/#post4321526
