Clutch issue, can't shift into gear
Apologies to all as I am new to this forum.
This morning as I was driving I noticed there was very little pressure in my clutch as I started it and was driving to work (takes 30 minutes) as I was pulling into the parking lot, I noticed almost no pressure in the clutch and it got harder and harder to shift into gear. Parked, turned it off, was able to move my shifter into any gear. Turned it back on, no pressure in clutch, couldn't put it into gear.
Right now, it's sitting in the parking lot. I noticed a spot underneath the transfer case/transmission, I couldn't really get a good look and I am not so mechanically inclined when it comes to cars, but not sure if it is from my Jeep.
Any idea what it might be and what I can do about it?
Is it a hydraulic issue? Had to replace the clutch and trans at 60,000 miles. The dealer couldn't tell me what was wrong with the trans, but the clutch had worn out with all my city driving.
My current odometer reading is about 106,000.
Any help would be appreciated.
I'm having the same issues,I was at work when it happened,I usually have mine in gear when I start it up,and when I did this one time at work it like tried to forward,and seemed like it was stalling out.so this past week I jus swapped out the slave cylinder thinking it has failed and bled it for two days and it still won't go into gear.any thoughts on what else it could be? I'm about to tow it to a mechanic cause I'm stumped.
As what everybody else said. Change out your master and slave. And make sure you check your brake fluid. Both clutch and brakes run off the same tank. Odd I know. The slave is black and mounted on the side of the trany. The master is also black and between the master brake and the fender. Had mine go out and the dealer is the only place to get them last time I checked. I don't know how easy they are to replace or to bleed, I was on a road trip when mine went out. It looks quite easy and I'm sure somebody has a write up on them. Again. First check the brake fluid then refill and bleed or find out where it is leaking. If it is leaking it should not be the clutch. If its under warenty then take it back. It is a " internaly lubercated part" if you want to really split hairs.
I had the same thing happen a couple months ago.could get it in any gear until I turned jeep off. I changed slave and master cylinder, and put new clutch in and problem was solved.
