clock loosing time
clock loosing time
So this sounds a little crazy. I took my Jeep in for some work as the warranty will be out in another 3k miles and mentioned that the clock runs slow and about once a month I have to reset it. He asked if I was also having trouble with the starter not kicking in with the key. I wasn't, but he then told he they have this problems in the Dodges as well and the problem is a bad ignition control module.
They replaced it - under warranty. ticket reads "1 - 5026071AR module-control module fc: UC Part#: count:" Since then (about 2 weeks) my clock has been right. I had to reprogram my spare key to the new module.
Do you think this is legit? I have seen other threads with either clocks that don't keep time or ignitions that don't want to work at times. I just can't imagine that the clock function for the radio would be held in the ignition module. But then again, you never know with these new fangled things!
wow interesting... in both of my JK's I have had the issue that the clock keeps crappy time... a local radio station here gives a "bleep" at the top of every hour from the atomic clock.. and I will set my jeep clock dead on with that radio station and within days ill notice it is off.. and in a month will be as much as 2-3 minutes... annoying!..
dealer just says it is normal for all of the 6 disc / DVD radios on the whole line of cars.. they have tried software updates, replacing the radios etc in the past to no avail.. so I just got used to it..
I dont have any starting problems.. and honestly after all the electrical issue in my last JK since this one is flawless except for that I have not wanted anyone to take anything apart or work on anything... dont want something to end up broken
-Christopher
-Christopher
Mine loses time too. I thought I'd bring it up to the dealership when I take it in to have them look at my steering clunk & see what they say. I'll post whatever nonsense they use to justify it once I take it in.
Only digital clock I have seen that can't keep time is the one on the RES head unit in our 2010 JKU. Only in a Jeep!
If the "5026071AR module-control" was the culprit I would have thought it would have been incorporated in the '10s unless it's production is more recent than my 10/09 build date.
same thing is happening to me.... my clock is 8 mins slow. if i fix it it just gets all messed up again in around a month, so i just am usually late everywhere i go
