Cleaning the inside of the frame?
Old 12-05-2013 | 06:35 PM
101gargoyles's Avatar
Former Member
Originally Posted by Sharkbait98
I forgot to mention I either do it in the front lawn or the easement behind my house with a long hose.
Being from south Texas where water is always a issue I have learned to use it wisely. I cringe every time I see water running down the street and not soaking into some green stuff.
I gotta agree with you as well
Old 12-05-2013 | 08:11 PM
boon4376's Avatar
Originally Posted by 101gargoyles
Why bother keeps the next run mud out.
We'll all be dead and gone before this causes a failed frame issue on a JK
Be a little bit environmentally conscious and think about where that tap water that has been through a costly process to get to you comes from.
The way I have seen TJ frames less than 10 years old rust to dust, I'd be a bit worried about JK frames just the same. Mud and dust in your frame holds moisture against the paint and metal for very long periods of time, compared to evaporation and run-off of bare metal. That's what causes the faster rusting.
I've seen people put tape over the holes in the frame with the idea that they can keep moisture out that way... the thing is that if moisture does find a way in it will stay in. Humid air trapped in the frame can still condensate on the metal, and will have a tougher time getting out since it can't breathe.
Some of us live in areas where water conservation is not really a problem. there are no droughts, and when we don't use the water, it runs from the lakes we get it from into the ocean. Plus hosing down the jeep is nothing compared to filling the swimming pool.
Old 11-16-2014 | 04:15 AM
Former Member
I think I might be able to make a million dollars or better yet...a BILLION dollars buying up all those TJs in Maine with their rotted out frames. Sounds like they all break in half due to corrosion frame failure.I'll just scoop up the huge piles of them in the scrap yards and sell all the good parts on E-bay. Please forward list of junk yards with a big enough pile for me to send a truck there for my first batch. There will be a small commission returned for your efforts.
Quick Reply: Cleaning the inside of the frame?
