Changing your transmission pan.
Obvious suggestions. Take 2 of the 3 bolts out of the trans skid plate and swing it out of the way. Use the rtv in a continuous bead around the pan perimeter and a loop around each bolt hole. Seal the non- blind hole bolt threads. Don't forget to r/r the magnet. Buy and use the allen headed bolts in the 3 front holes. (Makes the next pan removal much easier)Torque to specification all bolts. Be sure to re-attach the skid plate ( I know, it obvious) replace with new fluid amounting to the same amount that was drained. Re- measure when up to temp and selecting all gears on the shifter procedure.
