Changed my PCV valve
Changed PCV valve, found missing oil
I changed my PCV valve tonight. The write-up on this forum was excellent (https://www.jk-forum.com/forums/show...ling-PCV-Valve).
I have 22K miles on a stock 2010 and am burning 1qt every 2500 miles using dino 5w20.
I work for an organisation that maintains a vehicle fleet. After hours you can work on your own vehicle with a mechanic on duty to assist. I explained the oil issue to the mechanic and he said trying a new PCV valve was a good start. He told me to disconnect the hose at the intake side and look for oil there. Sure enough, that side was wet with fresh oil. I cleaned both ends of the PCV hose, installed the new valve and put everything back together. We'll see if this improves anything.
was the valve you removed stuck open or appear defective in any way?
https://www.jk-forum.com/forums/show...&highlight=pcv
I hope the new valve solves your oil consumption
FWIW, the new valve's rubber covering seemed a bit bigger in diameter. The old one was tight in there though, and I had to use the tie-wrap trick to pry it out.
