Change oil light?
#31
The OCI has no physical connection to the actual condition of the oil. It's independent, there isn't any sensor or other testing of the oil. The OCI just adds up certain weighted values until it reaches a set number.
If anyone is getting up around 10k miles and wonder if the oil has life left in it, send a sample to Blackstone Labs.
Or if the OCI has never gone off (and no one is resetting it on you) maybe it doesn't work.....
#32
Do people actually go by the idiot light & not check their oil???!!! We have to change it every 3000miles because by then the engine has burn 2-3L of the 4.5L of oil in it haha Dealership wont help and say it's supposed to burn oil. I give up on dealerships. Forget about the idiot light, just check your oil routinely & if you go 9000 miles without checking, without an oil change & the engine dies...good luck with the warranty.
#33
Good point Jiblet! I didn't realize the ECU doesn't have any sort of physical way to monitor the oil. (My wifes long-interval car does, so I assumed the same.)
So with that said, I'm +1 for being skeptical of the JK's oil life monitor.
#34
I can certainly attest to the fact that it NOT a viscosity detector. Mine usually chimes in shortly AFTER the oil has been changed. It is the most annoying indicator on the JK in my opinion. Wish there was a way to disable it permanently like the seat belt chime (many thanks to whomever figured that one out). The last time the OCI went off I was in stop and go traffic on the freeway. It chimed every mile for about 17 miles until i could pull off and do the sequence to shut it off.
#35
I've never heard of it going off during a drive nor repeating itself. Sounds like something is wrong with that.
BTW, Is your JK a late-model year '07? I thought the 07's didn't have the OCI...?
#36
The OCI should only chime once, and that should be a few moments after starting the engine, then not again until the next start unless the reset occurs.
#37
Yup, mine is an 07 and it does have the OCI. When it starts to chime it will continue until the procedure to kill it is performed. If you are moving rapidly it will only chime when you hit a stop light, but if you are in heavy traffic where you are stopping a lot it chimes once for each mile. I wish it didn't have it, or it could be shut off permanently. Once the chime is shut off it doesn't come back for a few months.
found it:
Project-JK.com - Jeep JK Wrangler Resource » TSB - FLASH: Oil Change Monitor Alerts Prematurely
Actually, your description sound a bit like the "mystery ding" from several years go, but I think that was for auto trans only.
When it dings at stop lights, etc. does the "Change oil" warning appear in the odometer or does it just ding?
#38
That sucks. I have never heard those symptoms before. Did you ever have a re-flash at a dealer? I remember a TSB for the OCIs back in 08.
found it:
found it:
When it dings it always displays the Change Oil in the odometer. I've never had the mystery ding issue, but I have seen threads about that here.
