Carwashing the jeep
At home - invest in one of the lower pressure (1500-1700 psi) pressure washers. The electric ones are great for small jobs around the house and have lower pressure than the gasoline power ones. They cost less than $150.
Also, if you do want to use the brush, use the high powered spray to rinse/wash the brush before it makes contact with the Jeep. It may take a little bit of extra time, but not near as long as buffing scratches!!
I knew about changing the fluids and rotating the tires but you mean I gotta wash mine too? I thought my color was called Mopar Poo Brown
In all honesty, I only hand wash mine or if mud is bad pressure wash it. The first time I took it on a trail I got tons of "custom pinstripes" and thought about buffing it out. The more I thought about it, I decided why bother I'll have to buff after every wheeling trip. As for washing, like others said spray off grit before any brush or rag touches the paint.
Engine de-greeser. I've got a stone white jeep, and the mud after it's caked on, seems to stain the paint. Blast the mud a few times with warm water, then after the majority of the mud is off, use the selection for the engine cleaner, I walk around the jeep twice spraying the de-greaser, Go back to the rinse option and rinse of the de-greaser.
I never use the brush, but I've got the trail stripes all over my jeep anyway. I just don't like the mud on my jeep when I get off the trail.
I would never use an automatic wash...plus mine would leak too much anyways !
I just use the hose and spray and spray and spray until alll of it is off. Then an old fashion hand wash.
A good at home detail job helps too. I buff it out with a random orbital buffer and compound, then use a high quality Carnauba wax. I usually buff in the spring, cleaner wax, then Carnauba wax once a month by hand. Meguiar's works well.....hint
All this keeps almost all the scratches out and keeps the finish nice. The monthly wax job now only takes me about 45 min to do.
If you wanna get rid of the scratches take it to a detailer. Detailers can work wonders with a PC 7424XP buffer or a Flex VRG, a bottle of poor boys SSR and some Klasse all in one, Clear Kote, Meguiars etc. You can also buy all of this stuff and learn how to do it yourself, way cheaper then going to a detailer in the long run.
Thanks for the info!
I think the brush didn't scratch my car, but the sandy mud did. It's real bad. I should have washed the crap off right after wheeling instead of waiting three days too.
I guess I will have it buffed out, and be smarter about it.
I am OK with the scratch and ding here and there, but this is all over my jeep
Hopefully they don't charge too much, cause I could of spent it on a mod instead!
