can't stop that banging noise....
anyone else have a banging coming from the passenger side dash? I have removed my glovebox, removed panel over radio, and felt around all under the dash. I have even tightened up the wiper motor cover on the outside. Even made sure my antanna was not loose. But still I have a banging noise coming from the dash.... any ideas without removing the entire dash panel?
Check your right front shock upper bushing and nut. If the bushing comes apart and/or the nut comes slightly loose it will cause a banging transmitted thru the dash....
